Slim,
Links, er no. Info, well not much. Most of my books are 20thC, that being where my interest lies; aimed at the hobbiest; and often post-war to boot. That means the bench designs in them have been influenced by the continental designs, by limited space and/or maximum flexibility and designed to make as little unlicensed wood as possible go a long way. However, taking a look at Salaman I see the following, which may be of interest:
Since the 18thC, a Vice with a long, vertical, wooden cheek has been common in this country (leg vice I assume?), either attached to the front of the Bench or standing separately - the Post Vice.
On the Continent of Europe an additional L-shaped Back or Tail Vice was fitted to the right-hand end of the bench top. (Benches so fitted are usually called German Benches.) <snip of using same with bench dogs for holding work> It may be wondered why the great convenience of this device for holding the workpiece never seems to have been fully accepted in this country. (too many Adam's about? :wink: )
The most commonly seen bench as far as
I'm concerned, is the basic joiner's bench, often of two slabs with a shallow tool well between, a deep front apron and a metal face vice at the left-hand end. Apart from the metal vice, I should think it's pretty much unchanged for hundreds of years. And it lives on in professional joiner's workshops up and down the country; I would also say "in schools", but alas, not any more.
To give you an idea, here's the bench at Finch's Foundry in Devon, which was used for general joinery, coffin-making and wheelwright work:
The business was going right until the 60's IIRC, so there's no telling when it was made.
As a rule I stay well out of bench design discussion; my view would not be a popular one. Seems to me you so often hear the gurus say "oh, I use that type of bench because it's the one I was taught on". Well could it be that the perfect bench design is the one you take time to get used to..? :wink:
Cheers, Alf
Who doesn't have the perfect bench either, but
is used to it.
