while sorting through some scrap brass and copper I noticed a compression joint that I’ve never seen before or at least not had the time to take a closer look. So having cleaned the pipe and fitting a little I came across a makers name - on the edge of the compression nut it reads ( the fyffe coneor joint ) a search on line led me here:-
Arrow@TU Dublin
https://arrow.tudublin.ie › cgiPDF
The Irish Plumber and Heating Contractor, March 1962 (complete ...
https://www.google.com/url?q=https:...EQFnoECBEQAQ&usg=AOvVaw2l4T-fWW74jXJGRj_dpq9X
I’ve never been much of a history nerd but found this interesting as the house it came from is old and having dug down to approx 1.2 meters the house appears to built without footings . These fittings and several meters of pipe were installed about 600mm underground with no obvious protection. The pipe is in good condition on the outside but inside the pipe is lots of green verdigris or corrosion. It’s clearly old 1/2 “ as it’s heavy compared to modern 15 mm by tube . I was quite impressed with the copper tube flared ends -a far cry from the push fit world of today . Many older plumbers and pipe fitters have heard of connex fittings but I’ve never heard of this Irish company..interesting to hear if anyone else has especially those from Ireland..
Arrow@TU Dublin
