Old power tools you still have, and which still function.
A Black and Decker DNJ62, two speed power drill I bought in about 1975. Still works perfectly, about 46 years old. I also have a B&D jig saw from the same time, which also works.
If it's the orange one with the flip gearbox I have the same one + lathe + sanding disc attachments.
Also a green Bosch circular saw and naerok pillar drill if they count?!
Cheers James
Festo track saw from 1993 or thereabouts. That and a Hitachi pillar drill from the 1960s. Was my great grandfather's passes for my grandfather and now mine in the 4th generation.
I also have a kity 637 from the 1970s from what I can figure out
That's the one, Built like a tank and weighs almost the same. When I fired it up earlier to make sure it still works, I was looking for the reverse switch to open the chuck quickly. :ROFLMAO: :ROFLMAO: . What a numpy!.
I have the long handle Makita cordless. Must have bought it in 1991. If I remember rightly I was still serving my time and earning around £60 pw and the drill was around £150. The batteries are long since dead though there is no reason the drill shouldn’t work.
I have an all metal body Wolf power drill that was my grandfather's. Only use it now to run a twist drill sharpening jig. Guess it was probably purchased late 50s early 60s. Built like a tank. Only thing I've had to do with it is change the brushes
Early b & d had large armatures proper hobbed gears and a manganese alloy body I still use one as a polishing rig real worhorse only thing that let's them is chuck size
If you turn those prices from 1975 into 2020… you will have a good comparison
If the batteries are dead, most would call that not working!
My last car worked perfectly except the brakes
A Denbiegh No 2 floor standing pillar drill, mid twenties and another un-named bench drill that is probably slightly older. Also the ubiquitous B&D orange bodied pistol drill and until I was given a new bandsaw, my old JCB bench bandsaw, still works, but retired.
i bought 5 of those long handled Makita's when I came back from Calif.....had to use an industrial 110v trans to use the orig charger to charge em....
you coudn't buy anything like it then....
surpisingly advanced for the time....B+D still had a service n spares shop in Salford then.....always busy....!!!!!!! lol....
It may be cheating, but I collect old power tools. The oldest I have is a 1926 Black and Decker drill, made in the USA, still works fine.
