Rupert_Bear
Hi all,
Motor gurus advice needed, please!
I have an old Coronet Major lathe, with an original type 2850rpm motor. Even with the belt set to lowest speed, it seems too fast for any turning over about 4 inch dia.
So I bought a newer motor, made by AEI, same size, single phase, 1425rpm, B56 frame, 5/8" output shaft, spins lovely. See photos. I fitted it to the lathe, to find it turns the wrong way! Aaargh.
Youtube has lots of advice for reversing the direction of start-capacitor motors (no, you don't just swap live and neutral!). But this one does not have an obvious capacitor, and when you take the wiring access plate off there are only two terminals, and no instruction for reversing. There is a spare terminal visible, but a multimeter shows it's not connected to any of the others.
Can I (should I?) take it to bits and see whether there in an internal connection to a starter coils that can be reversed, or take it as a learning experience?
Any advice appreciated!
Rupert
Rupert
