The Axi saw pictured is actually a clone of the Excalibur range of saws. Originally designed and made in Canada, then bought by General International (also in Canada) but made - to very high standards - in Taiwan. They are still available under various labels, including "Excalibur", "Pegas", and the pictured Axminster Trade, amongst others. But there have been a lot of complaint posts on here in the past about the 30 inch version of the Axi Trade version (doesn't seem to affect the 18 and 21 inch versions).
It was 8 years ago now when I had the chance to buy a "good" machine, and was able to compare/use a multi speed Hegner (I forget which model now) and an Excalibur 21 - thanks to Dictum in Munich. I found both to be VERY well made but chose the Excali as A) it was somewhat cheaper than the Hegner, and spares were MUCH more reasonably priced (!); and B) because of the tilting head instead of a tilting table. That feature alone is so much better and used much more frequently than you might think).
I have never regretted that choice and have used my machine a lot, in many cases for jobs a scroll saw is not really expected to do! (Amongst other attributes, the Excali will happily take bits of broken bandsaw blades , coping saw blades, and junior hacksaw blades as well as both pinned and pinless "proper" scroll saw blades).
But as well as the apparently troubled history of at least some of the Axi cloned machines, there are also some other versions floating around, mainly in the US, which are also apparently "less than good" shall we say!
It's about 2 or 3 years ago now (I think!) when there was a lot of traffic here on this whole subject and at that time I did some research and posted here on what I found out. After posting this I'll go and search for that then come back and post the link.
HTH
Add P.S. Here's the above link:
https://www.ukworkshop.co.uk/threads/excalibur-scroll-saws.135732/
