Woodernhift
Very much a sufferer of offcutit is, however I recently had a clear out and set myself a yardstick of “if it will not provide 4 sides of a box, say 200 x 150 mm“ then into the wood burner pile and winter is coming.
They do look good from the inside. And I'm loving the ebony.I sometimes use offcuts to make chopping boards but this time I thought I might glue them up for turning a bowl. The problem with doing this is after only a short while you can feel the difference between each strip as they all move at different rates so the glue lines are obvious to the touch. It's not a bad problem because I think it's still interesting to look at. There is some Mahogany, Sapele, Cherry, Ebony, Oak, Ash and Sycamore. It's 235x70mm.
Gary
Thanks. It might seem a waste of ebony too but it had that many shakes in it it wasn't much good for anything.They do look good from the inside. And I'm loving the ebony.
The string thing sounds suspiciously like Thurber's Aunt.Clearing my grandmother's attic, many years ago, we found three boxes, all neatly labelled:
"Cups without handles, Guide Camp 1927"
"Cup Handles, Guide Camp 1928"
"Pieces of String, Too Short to be of Any Further Use"
I Usually end up waist deep in offcuts as I never seem to know what to do with them. For some reason they seem to gravitate to the bandsaw area.I'm a bit of a hoarder and don't like waste - I can't bear to throw away offcuts, and as a result my workshop is getting fuller and fuller. I keep even quite small pieces - mostly cherry, maple and walnut.
Anybody got any ideas what to do / make with them? What do others do with their offcuts?
thanks, Andy
