Oak knot box, Finished!
Racers
22 Apr 2005
I was given this piece of tiger oak with a knot by Custard.
I am making a box lid with it, its been planed down to 15mm thick and the Wenge breadboard ends fitted.
I turned some 4mm Wenge dowels for the breadboard ends then drilled the holes at 5mm!.
I have a nice plank of brown oak for the box.
Oak and Wenge (Panga Panga) by Racers, on Flickr
It has a face!
Oak face by Racers, on Flickr
I am going to leave them open, I did think of ripping some off the back the inserting bamboo skewers and angles across the large one then re-joining it, but then I thought I like them how they are.
The knot is great, I've always thought defects like this should be celebrated - the face a sort of screaming chinaman (or is that just wishful thinking?). If it was me I'd have drilled 2 more holes at the other end to even it up and make it look deliberate - possibly with a small insert of some kind, ebony or some such.
Are you going to leave it open or back it with something contrasting, a bit of coloured fabric?
You're a clever man Pete. I never saw the potential in that off-cut but you've turned it into something pretty special. And I absolutely would never have thought of pairing Wenge with Oak, I tried it with some scrap pieces in my workshop this morning and they complement each other extremely well, the open grained texture is a very good match and the colours really work together.
=D>
I am planning a sliding internal tray in maple which will be visible through the knot.
Just don't make any Hobbit jewelry boxes from it Pete. You'll be getting a visit from Ian Mckellan.
I made a mistake with the measurements of the box which I didn't spot until it was glued up, I seemed to have added and extra 10mm to the depth of the box which meant the hinge layout I wanted to use wouldn't work, So out with the saw.
Cutting it apart by Racers, on Flickr
And then the shooting board and mitre sledge.
Shooting the miters by Racers, on Flickr
Nearly clean mitre just one more cut to go, note the maple strip to stop the grove splitting.
Nearly clean miter by Racers, on Flickr
I cut the sides to length and resized the bottom and glued it up with out the biscuits.
Oak Knot box by Racers, on Flickr
I cut the ends off the breadboard ends and gave the lid a coat of Danish oil, wow!
Lid with one coat of Danish oil by Racers, on Flickr
The box came out of the clamps and was fitted with some Wenge feathers and a clean up and oil, next the hinges I have cleaned up some nice brass ones, I will try and fit them in week.
More progress on the box.
I decided it needed a base to balance the overhanging lid, so I cut some strips of tiger oak that was an off cut from the lid and mitred it with the aid of my shooting board and an mitre attachment.
Shooting board miter attachment by Racers, on Flickr
I made a jig for my biscuit joiner to cut the feathers.
Biscuit feather jig by Racers, on Flickr
It does a good job.
Feather slot by Racers, on Flickr
Feathers glued in and trimmed flush with my shoulder plane.
Triming feathers by Racers, on Flickr
I pegged and glued the base on.
Wenge peg by Racers, on Flickr
I took a deep breath and cut the hinge recesses with my new Katsu trimmer on an extended base.
Katsu with extended base by Racers, on Flickr
With a quick clean up with the chisels the hinges look good.
Hinge by Racers, on Flickr
I put some masking tape on the inside of the lid and transferred the hinge location.
Transfering hinge location by Racers, on Flickr
Hinge layout by Racers, on Flickr
The hinge recesses where cut with the Katsu and chisels and the lid was screwed on with some temporary steel screws.
And it works!
Oak knot box by Racers, on Flickr
Now for some finishing and on to the sliding tray, I have some rippled sycamore and rippled walnut from Custard, I have plained the sycamore down to 4mm and the walnut to 5mm, just need to work out the method of construction mitres with feathers of rebates.
I am leaning towards mitres with contrasting feathers.
That looks fantastic, what a cracking piece of oak.
The misses has been asking for a jewellery box, i need to go and see custard!
Looks stunning that. I couldn't see the face until this pic.
With the lid closed it looks a little like the eye of Sauron. In a good way! Hence my daft comment about hobbit jewelry earlier. Learnt a trick or two just from the wip so thanks.
btw Nice to see your plane in the pics, oddly enough I was reading an old thread from years back of Jimi's just now and saw it, then like a bus it turns up again minutes later.
Chris
Thanks chaps.
With the lid open it looks like an elephant to me, I think I need a rest!
This is the sort of thing that shows the forum at its best.
Custard generously offers wood that he can't use in his exceptional, high end furniture, and Pete takes up the challenge. With his maverick inventiveness, he sees and makes what will surely be a wonderful, eye catching box.
And a very calm recovery from a measurement error to reassure the rest of us!
