Oak Alcove Units
BradNaylor
17 Oct 2007
Turning MDF into gold in a northern town
This is a job I've been on for the last couple of weeks. No photos of the workshop phase I'm afraid, but I thought I'd take some piccies of the fitting process so you can see how I go about things.
I started with two empty alcoves...
First step is to remove the skirting boards with the trusty Multimaster.
Then level up the right hand base unit using adjustable kitchen legs
Scribing the left hand base unit to the wall using my patented 'two biscuits and a bit of gaffer tape' system.
Jigsaw along the scribe line
There is always an electric socket to deal with. I cut a hole in the cabinet back a bit smaller than the socket cover
Then offer up the cabinet to the wall
Then unscrew the cover, flip it through the hole you've made, and re-attach it to the back box using longer screws. How neat is that?
I always use an end panel on the chimney breast side of an alcove
It makes for a neat finish and is really quick and simple.
The base units are then screwed to the wall with long screws and rawlplugs.
When fitting a top to an alcove unit, ALWAYS make a template. The best way is to use two pieces of hardboard or MDF and then screw them together where they overlap.
The top then simply slips into place. A few screws from underneath secures it.
Not a bad first day's work.
Day 2 starts with re-fixing skirting boards, installing plinths, and scribing the face frames of the shelf units into the alcoves
Domino slots were cut in the workshop for perfect location so all that is now needed is a line of adhesive, some Dominos and a rubber mallet. I really love my Domino!
Then bung in the adjustable shelves and fix the cornice...
Et Voila!
Thanks for looking.
Dan
This is an excellent walkthrough and nice work to go with it. Thanks for sharing. :)
Very good series of pics and a nice finished job.
I note that your "screwdriver" in pic 11 is remarkably like my hammer!
Richard
Interesting to see the approach, and a neat job as ever.
What you've done with the socket, unless you missed a step out in the photos is not compliant with the Wiring Regs, as I understand them (but probably common).
The back-box is supposed to completely enclose the electrical connections (or rather, the connections are supposed to be completely enclosed in a non-combustible enclosure mounted to the building fabric - I can't recall the exact wording).
It's unlikely that any disaster will come of it, but your insurer will dump you if anything did. As the customer's insurers would be after you and your assets to recover their payout, it's a small or very small risk but of a potentially very painful outcome.
Good work as usual Dan, make it all look so simple. Just surprised you didn't make your own veneered socket cover :wink:
Great work Dan, looks a treat.
To echo Jake`s comment on the socket, i`ve recently been pulled up on the exact same thing on a kitchen fit.
They wouldn`t even allow a surface mounted box & socket front inside a cupboard. To comply i had to just rout an access hole around the wall mounted socket, looked bloody awful. Luckily the customer didn`t mind.
Doug.
Great job as usual Dan. I was going to ask the same question as Nola about the hinges? I did wonder about those as yu have added the reveal piece to the fireplace side and these are in line with the doors, (or so it looks in the pics) I do like your method of scribing in the sides with the biscuits and tape, must try that one. :D
The hinges were fully cranked concealed hinges.
Unless a client specifically requests butt hinges, I now use concealed hinges on everything as they are so easy and quick to fit and adjust. And I hate fitting catches...
Customers are also now expecting a soft-close feature - even the ones wanting butt hinges ask for soft-close doors!
The cornice I make myself on the spindle moulder. It's too big a profile to cut with a standard block on a small machine like mine so I had a special set of cutters made that enables me to cut it from each side, meeting in the middle of the cove. Works a treat, and looks good on every job. Needless to say, every job gets the same cornice!
Thanks for the gen on the wiring regs, Jake. I'd been told by a sparky that this method was fine; in fact the guy who introduced me to to it was none other than that font of all wisdom Scrit, when I worked with him for a while.
Hmm.
I'll check it out on Monday. I might have to start using a surface mounted box instead. Pity, as this method doesn't involve disconnecting any wiring - or even turning the mains off if you're careful!
Dan
Dan,
That is a great how-to story. Two questions though. Your photo of scribing the upper section face frame for the alcove seems to show the frame already made and dry-fitted into the alcove. Had you already scribed it and were just checking for fit? Do you make up a template to do this?
waterhead37":1vrr433p said:
Dan,
That photo was taken after I'd scribed it and was checking the fit. To be honest the walls were pretty square anyway and very little work was needed.
I didn't template it as the face frame was seperate and could be offered up to the alcove easily. If it had been integral with the unit I would have used a template.
One of the great things about the Domino is being able to make strong but delicate face frames like this very quickly and accurately.
I'm glad people like the 'how to'.
On a job like this the planning and fitting is far more of a challange than the actually making, which is very basic stuff.
Dan
Dan
Dan
Couldn't you cut a hole in the unit back slightly larger than the socket box and then trim round with a suitably sized rebated moulding to avoid touching any wiring and leaving a neat finish?
Malcolm
