9fingers
I agree John. Now you have established that the switch is OK then the easiest/cheapest/most like cure is a new capacitor
Bob
Bob
Many thanks Bob for all your help and advice, I have been in the ws all morning on the corner cupboard project, my back is aching so will give it a rest for a few hours.9fingers":34y6jouy said:Ebay is by far the best source. just enter the capacitor value and motor run eg < 10mf motor run> and then check the voltage rating is equal or greater than the old one.
Some will have spade tags and others will have a short length of wire built in. Chose the nearest style to the old one. A quick check of the dimensions is advised but nearly all are standardised sizes for a particular value.
Try and stay within +/- 15% ish of the original value if you can't get the exact figure.
You should only be paying a few pounds.
eg http://www.ebay.co.uk/sch/i.html?_nkw=1 ... _PrefLoc=2
Bob
devonwoody":1vttrzc6 said:Pleased to say the capacitor arrived from Tyrone Ireland within 24 hours of order placed at Ebay.
BUT
The machine will now only run if I hold the green button on continuously, and the red button does not have any task it is dead when I attempt to switch over.
So I assume I have upset the switch mechanism when pulled out and dusted?
Is that your opinion too?
