That's where the profiled cutters come into play. And if a curve is needed but the cutter has a smaller radius ground on it, just step cut the work piece and with a file and some sandpaper bring it smooth.EdSutton":2cl8ackk said:There's a few reasons why I went for a dense hardwood rather than brass;
1. It would require 2" dia round bar, which would be expensive and you then end up turning away half of the brass you've paid for.
2. I wasn't sure how successfully I could turn the curve manipulating the X and Y controls of the lathe, whereas to form it with a round nosed scraper is more intuitive.
if not better looking! but I would have made the worksurface out of a piece of brass sheet or wide flat bar a couple of mm thick.3. The Rosewood is more tactile and also looks good
