Lons
Fitzroy":a7w5gqz5 said:Yup all in place. A concrete slab would have been the first choice but I live in a conservation area, so had to apply for planning permission, and the location for the building is under a set of protected trees so minimal allowable ground works. Hence the pier block foundations. It all rather is what it is, question was really asked from a learning viewpoint should I ever do it again.
The building is a glorified shed, yes I'll use it for my projects and it'll have some equipment in it, but not tonnes and tonnes of the stuff. I Plan to open a few slots up in the floor and see if I can insert some intermediate blocks for support mid span. I'll then fix the final floor boards over the Osb and history will be the judge. The whole thing is built on the cheap, but that's all I wanted to spend, you pay your money and make your choices.
F.
As long as you accept it maybe isn't as perfect as you would like it will be fine in that case, just don't let it get to you it's a great space. Life is far too short to worry about the floor being a little less than flat.
As far as the concrete base is concerned, in most cases you would have been allowed to construct that base because it would be above ground and not interfere with roots any more than your existing 100mm of hardcore does and in reality an above ground plinth is removable unlike concrete foundations.
I've been involved with several projects with grade 2 listed and conservation areas and although had to fight, they really can't refuse a reasonable project well planned and firmly argued. Different authorities can vary in their opinions of course so you sometimes have to be more assertive.
cheers
Bob
