Benchwayze
There is a bit of literature on the differences between polishing and grinding, in an old book, concerned with telescope making. (Amateur Telescope Making.. Vol 2)
It seems that with the finest of abrasives - (at the time the book was put together, jewellers' rouge was about the finest you could get) the effect on the surface being polished changed from grinding to a 'smoothing' action, almost as if the molecules were being pushed around and melded together, rather then being ground away.
I don't know how much truth there is in this, but it was thought to be the reason for getting a 'turned-edge' on a mirror, while polishing.
This turned edge could show on the back of a plane iron or chisel, if you don't keep the tool absolutely flat on the polishing surface, which also has to be dead flat.
If this all sound a little eccentric, I apologise. That's just me!
Cheers folks. Best of luck in shaving the hairs off your arms...
One day I might dare try shaving with a plane iron!
Yeahhh Okay!
- :lol:
Yeahhh Okay!
- :lol:
