dance
Hi!
I have found some space to do some woodworking, and in an effort to just get started and not spend ages faffing about without an actual project on the go, I have been reducing my expectations/wishes a little bit as far as my workbench is concerned.
Originally I had intended and hoped to make Tom Casper's torsion box workbench. Now, however, it looks like I'm going to be attaching a wide and long piece of rough ply to the side of my workshop and then attaching legs at the corners. Why rough plywood? Well hopefully because its width (17mm) and weight (heavy) will lend strength to my workbench. But as I'm still going to be attaching a vice, 17mm isn't thick enough - and I don't want the rough surface of the roofing ply to be the finished work surface. I would also like to add a trim of softwood to the sides (with 45 deg. mitred corners) but obviously there isn't the width in 17mm to attach the trim to!
So, any thoughts on how to resolve these problems? I have my own thoughts, but it would be great to have some feedback on them.
I have considered doubling up the ply (attached with glue and screws from underneath) to make a 34mm thick bench, but I don't know if this will help with strength all that much and it's still not a very thick edge to attach my trim and vice to.
As for the rough top surface, I wanted to cover it with a nice bit of knot free higher quality plywood/veneer. What sort of thing should I be asking for at the timber yard? I'm not used to buying plywood at all. And price I should expect to pay per m2?
THANKS!
THANKS!
