Phil Pascoe
Cans that would be extremely difficult to refill.GLFaria":r0td8ikc said:And I don't smoke, so I have no idea at what the fluid comes in...
Paper backed, wet and dry.Jacob":142knzck said:Has to be paper backed (not cloth - wrong material altogether for flattening). Though I notice "latex" backed in some ads - don't know if this is the same stuff, probably is - makes sense - the water (or white spirit) helps it stick by "suction".
OK get a new flat sheet from the pack, lay it on a pool of white spirit on your table (impermeable - steel, plastic, glass etc) pour more on top, wiggle it about and squeeze the liquid from under, gently start the grinding op but pinning the paper down with a finger if it's still floating about. Eventually it is pressed flat and won't move, keep flooding with fluid as necessary.GLFaria":30gpw2gj said:Paper backed, wet and dry.Jacob":30gpw2gj said:Has to be paper backed (not cloth - wrong material altogether for flattening). Though I notice "latex" backed in some ads - don't know if this is the same stuff, probably is - makes sense - the water (or white spirit) helps it stick by "suction".
Thanks, I will give it a go.Jacob":107yav8v said:OK get a new flat sheet from the pack, lay it on a pool of white spirit on your table (impermeable - steel, plastic, glass etc) pour more on top, wiggle it about and squeeze the liquid from under, gently start the grinding op but pinning the paper down with a finger if it's still floating about. Eventually it is pressed flat and won't move, keep flooding with fluid as necessary.GLFaria":107yav8v said:Paper backed, wet and dry.Jacob":107yav8v said:Has to be paper backed (not cloth - wrong material altogether for flattening). Though I notice "latex" backed in some ads - don't know if this is the same stuff, probably is - makes sense - the water (or white spirit) helps it stick by "suction".
Store your paper between boards so that it stays flat.
OK get a new flat sheet from the pack, lay it on a pool of white spirit on your table (impermeable - steel, plastic, glass etc) pour more on top, wiggle it about and squeeze the liquid from under, gently start the grinding op but pinning the paper down with a finger if it's still floating about. Eventually it is pressed flat and won't move, keep flooding with fluid as necessary.GLFaria":1owaq053 said:Paper backed, wet and dry.Jacob":1owaq053 said:Has to be paper backed (not cloth - wrong material altogether for flattening). Though I notice "latex" backed in some ads - don't know if this is the same stuff, probably is - makes sense - the water (or white spirit) helps it stick by "suction".
Jacob":s9hjquk7 said:OK get a new flat sheet from the pack, lay it on a pool of white spirit on your table (impermeable - steel, plastic, glass etc) pour more on top, wiggle it about and squeeze the liquid from under, gently start the grinding op but pinning the paper down with a finger if it's still floating about. Eventually it is pressed flat and won't move, keep flooding with fluid as necessary.GLFaria":s9hjquk7 said:Paper backed, wet and dry.Jacob":s9hjquk7 said:Has to be paper backed (not cloth - wrong material altogether for flattening). Though I notice "latex" backed in some ads - don't know if this is the same stuff, probably is - makes sense - the water (or white spirit) helps it stick by "suction".
:lol:Bluekingfisher":2h478aks said:Jacob":2h478aks said:OK get a new flat sheet from the pack, lay it on a pool of white spirit on your table (impermeable - steel, plastic, glass etc) pour more on top, wiggle it about and squeeze the liquid from under, gently start the grinding op but pinning the paper down with a finger if it's still floating about. Eventually it is pressed flat and won't move, keep flooding with fluid as necessary.GLFaria":2h478aks said:.............
Sorry to labour the point, but have you found the white spirit to be compatible with long term exposure to a cast iron bed of your planer or table saw bed.
You see I'm a little prissy over my gleaming cast iron tool beds and don't relish immovable stains caused by the spirit.
DC - Mr Grimsdale's point about skipping grits is that scratches at worst do not affect performance, and may indeed reduce stiction, so once preferred tolerances have been reached, it is only neceassry to polish the peaks, not remove the troughs.
Stiction? Really? At 60 .. 100 .. 240 .. 400 grit? I get stiction on a flat 8000 grit Shapton. I very much doubt that you could induce stiction on a jack plane on coarse sandpaper. :lol:
Regards from Perth
Derek
dunbarhamlin":2a5awl89 said:How much is too much? One penny more than you are happy to pay. I'm sure Holtey, Marcos et al would make a jack plane for you if you have the budget and the inclination.
How much is enough is probably a better question, and for typical jack usage (as a rough prep tool) very little need be spent.
BB - for localised high spots straight from the factory, check any unfettled CS88. Goodly sized bump just behind the mouth. As you say, easily remedied.
