Adam W.
A Major Clanger
Why do I miss the point if the whole point of me working with wood, is to work with wood?
Maths is OK between consenting adults.MDF and maths of course.
Nobody said you cannot work with wood Adam, as you are well aware. And besides, Im not really addressing you in this, more a general thumbs up for the stuff.Why do I miss the point if the whole point of me working with wood, is to work with wood?
Yes formica is good. I'd be happy with only wood, glass, formica.I'm not a fan of MDF either solely because it's s cheap imitation of real wood; and I'm proud to say there is no MDF anywhere in my house. Thats not that I'm against any man made material masquerading as wood; I like a bit of formica, makes a lovely covering for tables and other flat surfaces !
If it gets wet it self destructs.Great material to veneer on, totally unaffected by seasonal movement,
What's wrong with grain?and as the main panel on a door thats getting painted its so much better than jointed up or plywood in that theres no grain.
But each to their own.
For a super smooth finish on painted surfaces grain patterns are not particularly wanted. So painting, on a grain surface you paint, sand, paint, sand some more, and some more of that, then get the top coat on. Not so with a smooth surface like mdf, . Less sanding, less paint, less time spent.What's wrong with grain?
You've obviously never seen OSB used in a decorative setting and treated correctly. Structually it can hold it's own pretty well, I;ve made seveal items from OSB, including a almost 2m tall pair of shelving units, sanded stained and varnished and it;s a lot more interesting that plain plywood and has not bent twisted or warped like wood can. Cheaper too, and way stronger than laminated chipboard.Not a fan of MDF, still less OSB, nasty stuff.
I tend to use a short bolt to wind them in with, that way the head wont shear off and the body cant crumple upAnything not from a 'high end' named brand at Screwfix. Quality has gone to hell lately ESPECIALLY insert nuts or anything brass coloured ( powdered metal rubbish)
wont even go into bloody 12mm pine without the heads shearing off... 5 from 26 and a right bustard to get back out
I'm talking about using other forms. You seem adamant that mdf or 'flat' wood products are not fit for use.
I'll hazard a guess you arent including plywood, despite it also being flat and as you say lifeless.
Yes nails are brilliant and under appreciated. One tip is to pre-drill, depending on circumstances.oddly I'm of the opinion use of nails is a dying art. anybody who has ever tried dismantling a cut roof will concur. a touch of rust just adds to the grip. they seem rough but are strong and cheap. cut nails are just amazingly strong. I think nails and red deal are made for each other.
Like current paint - dries so fast you can't paint a door without going over half dry paint, everything has to be fast.No nails and such are for builders to stick mdf skirting and architrave down fast, as well as a lot of other stuff such as internal stud walls to the floor. If you are fitting skirting that is a bit nicer and ornate than mdf then use brads or pins which leave very small marks that are easy to fill.
