johnny
defsdoor":1l3xrz2f said:I'm not sure why you think I'm doing this bit by bit. .
well maybe its because youve cleared the site and started talking about construction and material sizes but you don't seem to have any idea about your overall design or given any thought about how your shed is going to be constructed. :wink:
You are talking about height restrictions but I thought that you intended to build the shed a minimum of 2.0 metres from any boundary . ?
if there is a 2.5mt height restriction due to permitted development limitations then this should be your first concern and will largely determine your ground levels , workshop design ,construction methods and materials. 2.5m is extemely restrictive and you'll barely have sufficient headroom inside your workshop with a pitched roof construction and the roof will have insufficient fall for rainwater runoff.
if you have a 4'0m height restriction then there shouldn't be any significant problems with height but you need to bear in mind that a Planning Officer will measure the overall height of your structure from the lowest natural ground point around your workshop.If you excavate to reduce levels then the measurement will be taken from an average of surrounding original ground levels prior to work not from your new ground level .
I would suggest you start at the finished surface of your original concrete base as your datum .
Find the lowest point of your original natural ground level where you haven't excavated it. Add or subtract to your datum point depending on whether the concrete is above or below the original ground level. That will then be your new site datum. Hopefully you won't have a minus figure
Then add up the height of all your construction from your datum point and subtract it from your height restriction and you'll know if you have sufficient headroom or if you'll need to alter your construction design to keep under that height.
you might find this base system of interest .http://www.shedbase.com/quickjackpro/
