mickthetree
Morning all
The ground has been cleared and hardcore in and compacted.
I am going for 4800mm x 6700mm. With 100mm wall thickness this will give 29.9 square meter which is just below the 30 allowed within permitted development. The building is over 2m from any boundary so the ridge height can be max of 4m
This is the general construction idea so far. I would like to get a small area at the front upstairs for some storage, but the rest I plan of raising the joists to collar ties instead. Although the idea of having a ceiling with insulation and a ventilated roof space for storage is appealing.
Lots of inspiration from Mikes shed guide and others.
Questions:
1.) In this sketchup model I have the roof timbers as 100mm x 50mm (2"x4") Should these really be 150mm x 50mm? (6"x2")
2.) If I cannot get hold of a Paslode, what would be the correct type of nails to use? Galvanised? Bright? 100mm, 125mm, 150mm.
Questions:
