Sheptonphil
Scrumpy junkie
MikeG.":2ln3f6li said:Double your wall plates and you don't need to line up trusses with studs. Having said that, I built my workshop with studs on 600 C's. There's no need for 400 C's unless you're lining the inside with plasterboard, and even then, you can use 15mm plasterboard at 600 C's.
All internal walls will be fireproof plasterboard due to the 'predominantly fireproof' regulation except the house wall which will be Acoustic Plasterboard, so I will put 15mm boards all round for the little extra in cost.
It was as much about the strength of the end walls taking the load, and whether they would benefit from 400mm studs. I could do as you suggest, double up the wall plates, 400mm stud spacing on end walls, and 600mm for the trusses (they are manufactured on assumed 600mm spacing).
Thanks again for your input Mike.
