Cegidfa
Hello folks,
I was beginning to think that I would never get to this point; what with shaping the windows and then three coats of paint, rubbing down, and a week off with friends visiting.
See the finished products below, prior to installing. They are held in with neutral curing low modulus silicone, not the cheaper aceytoxy stuff that reeks of vinegar.
Warning! If anyone is contemplating using Sadolin Superdec paint.....DON”T.
This was recommended on this forum a while back, but since then, it has been taken over by Crown, instead of Akzo Nobel. It is now officially ‘crap’ (a technical paint term), and very thin crap at that. N.B. rubbish is not the word I used...what a diplomatic program this is. Where two or three coats should have done, it would probably take six to get a decent cover. I wondered if I had an isolated case until a web search was done for ‘Superdec problems.’ This raised professional painters fora, and they were less than happy. Even worse was the treatment by Crown, who suggested they send them the 2.5 litre cans...and no they didn’t have a problem. Can you imagine the cost, and waste of time to a busy tradesman?
So I used Akzo Nobel’s Rubbol primer and top coat; first class stuff. I bought it from a Dulux centre, and asked about the Crown problem. They said that if there was ever a problem, that some of the offending paint should be put on a piece of paper and taken back to the shop, who would send it off to the manufacturer. What a different approach. Rant over.
It’s high time for an update on the costs.
Flooring and insulation (30mm) £618
Floor paint £50
Window wood £44
DG units ....four off £115
Rubbol primer and t/coat £48....2 off 1litre tins
Abortive Superdec £69 ....2 off 2.5 litre tins...used on the main windows and fascias, many, many times.
Plastic angle £57 50 x 50 x 2mm ..3 off 5m lengths. This will cover the window flashing and finish the face.
Total cost to date.....£5000.45p. :shock:
And I still have to insulate the roof and clad the whole inside...oh yes, and buy 600m of feather edging and paint it....glug. Not to mention two double doors with dg panels and ‘Spaniel’ locking.
I’m off to lay down in a dark room........and to rub it in, I became a pensioner today.
Regards...Dick.
Floor paint £50
Window wood £44
Regards...Dick.
