Paul Chapman
That's looking really good, Karl.
Cheers :wink:
Paul
Cheers :wink:
Paul
Karl":i87cv85q said:Still haven't fitted the chain - can't get the bugger to work. There is too much slack on it to work effectively - every few rotations it will "slip" on one of the cogs. But it isn't slack enough to use the 1/2 link which is supplied with the kit. :?
Paul Chapman":2sygh88o said::wink: :wink:
I must get one of those twin-screw vices when I can afford it - I reckon they are the dog's whatsits 8)
Cheers :wink:
Paul
EdSutton":4suapo6c said:Looks excellent Karl.
Have you seen this new surface clamp from Veritas - would make an excellent tail vise on this setup. I fancy one when they come out here in the UK.
http://blog.woodworking-magazine.com/bl ... erica.aspx
Ed
Karl":bf9glaxf said:Bet it won't work out cheap though......
Karl":140aays7 said:Looks like a much better idea than using the wonder dog i've got at the moment!
...and that's the thing that I'd be worried about. A tail vice (either the traditional sort like I use) or a vice mounted at the end of the bench (like Paul's) is always IMO going to be better simply 'cos the dogs can be located below the surface of the workpiecePaul Chapman":1cru2mm2 said:Karl":1cru2mm2 said:Looks like a much better idea than using the wonder dog i've got at the moment!
While it's an OKish idea, I think it would have problems in use. The main problem is that it's always going to stick up a certain amount above the bench top (and in some cases higher than the piece of wood you are working on) - unlike traditional dogs in the bench top and vice, which can be raised or lowered as much as necessary. Better than nothing but nowhere near as good as traditional dogs, IMHO.
Cheers :wink:
Paul
Ed - in the pic, which piece are you planing? If it's the middle bit (which looks about 6mm thick) it's clearly below the brass bit of the Vdog - RobEdSutton":2vhelzj1 said:Well you can hold thin stuff - you just need some thin battens (mine are oak in various sizes) to act as spacers.
I'll save you the trouble of telling me that if you have to make your own wooden spacers that its not a complete system (ref - honing guide discussion) :lol:
I'm not disputing that a traditional tail or wagon vise is better, but if you don't have one I reckon the wonder dogs or the new surface vise are a good option
Ed
Thanks Ed...all is clear - RobEdSutton":2ocp8wl3 said:No its the other bit - you cannot see the dog beyond the end of the piece.
Ed
