mailee
Ah I see, those panels are to separate the wardrobes, so the outside panels will be solid?
mailee":2sfv002i said:Ah I see, those panels are to separate the wardrobes, so the outside panels will be solid?
mark aspin":2g6qwarz said:Found them!
Scott and Sargeant sell them, as do Felder but they're more expensive.Dibs-h":5u76lb7f said:Where?
It helps Mick, but doesn't eliminate them. Before the 'organised' and 'methodical' bits you need to add 'stop' and then 'think'. Very often I remember the first two bits but forget the last two which has resulted (more than once) in feeding an entire job through the bandsawMickCheese":3huzuw1j said:One thing I do take from all of your postings is that I must be more organised and methodical, that I believe will reduce my sometime stupid errors.
Mick
Happens to us all Mick at some point, but it's what you do to get round the error which determines whether it's a 'bodge' or a cunning 'fix' (hammer) Sometimes though, stuff that I've done has been so appalling, without any prior thought, that it's impossible to either bodge or fix, in which case it's only fit for bandsaw fodder - RobMickCheese":3d2lf8o9 said:Then I have to find an alternative method, better known as a 'bodge'.
Is it just me? :roll:
Mick
mailee":19rbk29p said:Looking good so far Rog. I wouldn't fancy manhandling that up a flight of stairs though. :shock:
Ah, I did wonder. How will it be assembled once on site, glue and clamps, biscuits, screws?Dodge":3nm2kh2h said:mailee":3nm2kh2h said:Looking good so far Rog. I wouldn't fancy manhandling that up a flight of stairs though. :shock:
Neither do I! That's why the whole thing will come apart again
deserter":1zpcdvdt said:Your not working too hard again are you? Your speed seems to be the same as always.
~Nil carborundum illegitemi~
