LancsRick
Is that an exceptionally hefty extension table to the right of the TS Custard, or the back end of a planer?
LancsRick":1k26p2cy said:Is that an exceptionally hefty extension table to the right of the TS Custard, or the back end of a planer?
custard":196crv29 said:You can go round and round this issue until the cows come home, and of course differences in what you make will be decisive.
custard":196crv29 said:But as a general rule for smaller workshops, where space is the critical constraint, I'm not convinced that a budget table saw is always the best use of funds. If you work solid timber a bandsaw with it's small footprint can often be the best ripping solution, for breaking down large sheet goods a track saw has a lot going for it, an MFT table is supremely versatile not only for cross cutting but also doubles as a precision assembly table, and a decent mitre saw is very compact and delivers virtually polished end grain cuts.
Regarding a separate track for the MFT, I think they are sold individually, but one call to a dealer like FXX Tools will resolve that.
Good luck!
LancsRick":g481boju said:Your other option if you do a lot of cross cuts and only the occasional rip would be a radial arm saw. You can then rip material with either your track saw or the RAS, and they are extremely accurate for cross cuts.
Bacms":2830fwt3 said:At the moment I am more tempted by the UJK MFT. This would save enough money...for me to also buy a mitre saw.
