New project for work
Stigmorgan
UKW Supporter
18 Aug 2019
Ash Vale, Aldershot
So the headteacher has asked about installing some benches under a shade sail that will blend in with the woodland theme I've been creating on site, my first thought is to keep it simple and use sleepers, I can make 2 benches from 3 sleepers if I cut 1 into 4 pieces at about 600 long and concrete 300 into the ground, this should give a seat height around 400 above ground, my dilemma is which sleepers would be best, they are all 2.4mX100mmX200mm
Treated brown hardwood
Treated brown softwood
Treated green softwood or
New untreated Oak
My personal preference would be oak but will it last being untreated and concreted into the ground?
Cost isn't an issue, I've given the school my "quote" based on using the Oak sleepers which are the most expensive at £49.95 on the website but the company have always given me a good 15-20% discount and free delivery when I order stuff for school as they are literally across the road
Just a quick observation, I know you will know, but if I were making a seat, in this environment, I would be cautious using Oak, as it will release Tannins and treated timber may leach out any treatment/colour, when it gets wet, and consequently run the risk of staining etc.
There are regulations for "playground furniture", and the materials allowed to be used, along with maintenance conditions, whether they would apply in this case I don't know, but we have to have inspections on the gear we have at the village hall public play park.
best wood might be something like greenheart or opepe or ekki (though sharpen your chainsaw!)
they are all used as marine timbers for dockyard gates etc and are fairly indestructible - I have offcuts for sitting around the firepit and they happily sit out in all weathers and will outlast me!
I made some simple benches from treated softwood sleepers for the woodland a few years ago.
One sleeper per bench, just dug into the ground and lasting very well.
Recessed the uprights into the tops, nice tight joints to help reduce racking, and secured with timberlok screws at an angle from below, nice and solid :)
I used to make green oak furniture for exterior use for the National Trust. We also used kiln dried oak for more complex work like the Lutyens and Clem Churchill benches at Sissinghurst and Chartwell. Sissinghurst gets about 200,000 visitors a year, many gravitationally challenged, and they survive that!
Green oak is heavy and hard to work with, but superb for rustic exterior benches & tables etc.
Never any problems with leaching of tanins etc. just need to understand seasonal movement.
Oak is the National Trust's wood of choice for exterior furniture.
https://www.ukworkshop.co.uk/threads/post-a-photo-of-the-last-thing-you-made.81798/post-1492484
Greenheart survives by being a pretty noxious timber, One certainly wouldn't want a splinter of this especially not in ones rear end as they can go septic. :giggle:
This is exactly what I have in mind except they will be 2.4m long and heavily concreted in, the kids will likely climb on them more than sit on them and the ground has only had 5months to settle since the newbuild was completed, being under the shade sail has the bonus of keeping the worst of the weather off the benches
Those regulations apply to equipment like climbing frames and ropes rather than seating and tables, all of our trim trails and adventure playgrounds are inspected annually, they've never wanted to check our picnic tables and benches.
Definitely oak. I’ve used untreated oak for a couple of garden fences specifically because there’s no need to treat them and they are still perfectly good after 10 years.
I think your only issue might be having to concrete them in. The concrete will retain moisture so the legs will end up being damp, and will ultimately rot. It might be a good idea to add plenty of rubble to your mix so that you end up with something pretty porous. It sounds like you need the weight of the concrete rather than ultimate strength. Also consider using hydraulic lime (NHL 3.5) rather than cement. It will set just as quickly, but will not retain moisture.
Correct the concrete will be more stabilisation, the ground is very well draining but most of the leg will be in the topsoil layer (300mm-ish) so will look into getting the lime instead of postcrete and paint the ends with some bitumen (i have a tin of roofing felt adhesive somewhere)
Don't get me wrong, I'm not adverse to using Oak, that's pretty much all I work with, I make quite a few Oak garden seats and benches, but use KD Oak, and don't have the issue of the Tanins washing out, whereas when I've used green or air dried Oak in my construction builds, for a while the leaching is very evident.
But as its under a cover this may not be the case.
When I plant posts in the ground I wrap a bit of DPC/plastic around them so at least an 1" of it is above the soil line, certainly helps to stop the rotting at that point.
I had to replace my 8" Oak front gate post last year, had been there since 1989, as it had given up, but that's had a 12' 5 bar gate swinging on it all this time, so longevity for a bench wouldn't be a worry.
Stig Morgan we did exactly what you are planning. The PE dept wanted simple but sturdy benches along a bank top between astroturf and a cricket pitch so spectators could use same bench to watch both areas. It was a project under taken by6th formers as part of their enrichment program activities- doing something good for others while working in a team
We used softwood sleepers full length 2.4m supported by 0.8m uprights set in from each end. Kids dug the holes and planted supports with postcrete. For extra stability a 25mm trench was cut into underside of seat for the supports on radial arm saw. (I don’t think that this was necessary as they seemed pretty bomb proof with the big rag bolts.) Seats were held in place with something like 250 mm coach screws in holes plugged with bungs then all stained dark green once completed.
Well everything has been ordered, screws, postcrete and 12 sleepers, the plan is for 10 benches, the 2 extra sleepers plus offcuts will cover my labour 😊
Hoping it will be delivered the week before half term so I can do most of the cutting during the week then install during half term.
How deep should I cut into the top for the legs to recess into? I'm thinking around 30mm, I plan to cut the legs at 1m long and sink them around 600mm deep, the ground was disturbed quite a bit when our new building was built in August so has only had 6 months to settle back down so want to be sure I'm into stable ground.
Sounds about right to me, the rebate in the top is just to locate it on top of the uprights 25-30 mm should do fine. When the kids did them they assembled the top onto uprights then carried them to the site and lifted whole structure into the holes got it level then poured in the post crete. This was the most fool proof way we could do it!
That's my plan, delivery will have to be to the front of the school, I can do all the cutting there and then carry everything through the school, build the seats then put them in the holes and concrete in place, 1 bag per leg should be enough.
30mm doesn't sound enough to me, deeper and tight joints will help resist racking. Timberlock or other long screws will help with that too of course driven in from below at an angle, but the more depth the better really.
Think I did mine about 40mm or 50mm, as deep as I could easily manage with the tools I had and without compromising the depth in ground and finished height :)
