New project for work
If you do use softwood beams I would give the ends that are going into the ground
several coats of Bitumen up to ground level , It will help stop rotting.
Not so, any timber set into earth will rot at ground level, therefore protection needs to extend above that level, heat shrink wrap can be obtained to do this or just simply bitumen, but this is prone to damage when strimming etc:
Would 50mm not be too much into a 100mm (probably actually 90mm) sleeper?
The area will be woodchipped so use of a strimmer would be minimal and by myself so that wouldn't worry me too much, I plan to paint with bitumen then use a heat gun to get it soaking into the surface as much as I can.
30mm doesn't sound enough to me, deeper and tight joints will help resist racking. Timberlock or other long screws will help with that too of course driven in from below at an angle, but the more depth the better really.
Think I did mine about 40mm or 50mm, as deep as I could easily manage with the tools I had and without compromising the depth in ground and finished height :)
We cut the trench on a radial arm saw so it was a snug fit then put 9 or 10” coach screws straight down a drilled hole then capped with a wooden plug. We put about 10 benches in place all well tested by the enthusiastic supporters, nothing has moved yet !!
Stig, we used to burn the leg's that would be in the ground then soak the ends for a week in old engine oil and before they were dropped in the hole a good dose of bitumen.
Fencing posts also had the same they last for years and years.
I won't have time to leave things to soak, I will only have the half term week to get it done as well as letting contractors into the building and keeping an eye on holiday club.
How about canting the legs outwards as this will lock the legs into the top and also into the ground say 10-15°
Back in the 60's I lived and worked on a farm and the old feller used to have a fire pit and he'd put Oak and Ash stakes and posts over it to burn the ends that went in the ground then a week soaking in oil before stacking point up ready to take out on a job.
He also used to take Oak chippings and shavings put in a cloth bag and hang it in his barrel of beer said it gave the best taste ever, nothing was ever wasted.
So apparently as we claim the VAT back i had £130 left from the money the pta gave for this project so I've added 3 more oak sleepers to the delivery as I have an idea that, if it works, will be a nice surprise for everyone, in Jan 2023 a large Ash was felled across the road from school and I managed to snag a lot of it, among this stash was a (not well cut) cookie, I painted both sides and have had it stood on edge since then, rotating it every now and then, I've have an idea to use it as a table top if I can get it cleaned up and fairly flat, this is proving easier said than done, I spent all afternoon on the better of the 2 sides with my electric plane and started the 2nd side, it's hard going in the middle where the wood is still hard, I may dig the chainsaw out tomorrow and remove the bulk that way, hopefully I won't find another nail like I did with the plane, I'm hoping tonhave around 2.5 inches of thickness once it's done.
If I get it flat (ish) I will then have a go at doing some bow ties for the bigger cracks and leave the smaller ones, I have some old oak sleepers i can make them from. I'm thinking an oil finish would be best but on the other hand the spalted areas are quite punky so perhaps saturating with CA then a yacht varnish finish 🤔
So today I got one bench roughly done (too many kids around to take pictures) it's not great as my little circular saw is rubbish, luckily the oak is quite wet so cuts fairly easy, I'll take some pics over the weekend to show what I'm not happy with, maybe you guys will have suggestions.
This afternoon I used chainsaw to remove the bulk of the extra material on the Ash cookie, some of the spalted areas are tearing out a lot so gonna have to stabilise them before removing more material, I think k I've worked out placements for bowties and have cut some scrap oak to make them from. Once I have the wood stabilised and bow ties installed I'm thinking of making up a router sled to flatten the cookie.
20250213_162011.jpg20250213_162014.jpg20250213_162019.jpgIMG-20250214-WA0000.jpeg20250214_152628.jpg
View attachment 197831View attachment 197832View attachment 197833View attachment 197834View attachment 197835
Router sled will make a good job of that but it will probably twist and turn a bit once installed
We had a chainsaw totem pole carved for a child who got killed after getting off school bus -full of memories from her friends, it was carved torched painted with preservatives and decorated with high pigment paints but sadly after a couple of years wood peckers made a start on it so it had to be cut down and it became a table!
The best laid plans of mice and men…..
I fully expect it to move, it will be outside in the school, chances are the kids will destroy it before the weather does.
He’s a lot of this stuff is transient but your benches should last well
I hope so, the reason I decided on oak instead of cheaper softwood was they need to hold up to primary school children, many with behavioural challenges plus the supplier only charges me £40 each for them which I think is really good for a 2.4m x100mmx200mm piece of green oak.
Got quite a bit done today, once I'd opened up for holiday club and fixed some lose carpet I headed out to continue with the oak sleepers, I now have 2 benches ready to be connected and 2 with the mortise cut ready to remove the material, first thing tomorrow I'll cut the 5th one then set to with the chisel and get them all ready to screw together and paint the lower 600mm of each leg with bitumen.
One thing I've learnt- the plate on my circular saw is twisted making it impossible to get a good 90 degree cut and it's awkward to make adjustments to cut depth and angle, it's OK for ripping ply but for this work it's not great.
Under normal circumstances I'd leave the rough finish but as it's for school I think it needs cleaning up so going to bevel the edges around the top (either with a plane or maybe I'll try out the router I bought years ago and have never used) then hit the whole thing with 80g
20250217_125944.jpg20250217_125949.jpg20250217_125954.jpg20250217_130002.jpg20250217_130006.jpg20250217_132403.jpg20250217_132805.jpg20250217_170747.jpg20250217_170753.jpg
