Jacob
What goes around comes around.
But all the old planes I've ever seen don't have this done, old woody or a Stanley. I've had several job lots of oldies in all conditions so I have seen a lot of them. The reason it isn't done is because it isn't necessary. Instead they all seem to have used the ruler trick without a ruler i.e. just a little flattening towards the edge.Peter Sefton":1tb57uv9 said:.......
The fattening and polishing of the back of the blade is a one off process in the life of an iron, so between 10 and 40 minutes for a blade that lasts years.
In any case it wouldn't last for life - the face gets wear as well, not to mention rust and other accidental events
No it isn't - it's a recent fashion....This is common practice with a chisel
It is a major issue when you read the misinformed struggles of a newby who had been desperately flattening the faces of a perfectly OK set of new chisels because of some nonsense he has picked up off the net, and spoiling them in the process - working his way through reams of ever finer wet n dry and wittering on about glass/granite plates etc.and it doesn't seem to be a major issue,
Sharpening a chisel is never easier than when it's brand new and should take half a minute or so.
PS the new sharpeners obsession with removing grinding marks is also pointless - any friction they cause disappears very quickly with use, or or even quicker with a quick pass over a fine stone, to take the sharpness off.
