Alie Barnes
Hello
Well i finished my Elm bowl, finished in Danish oil.
Now for the problem, i mounted the log on a faceplate and rounded and trued it all up, shaped the base and put in a tenon for the chuck.
when i turned the piece round and put the chuck on it was slightly out of centre, why is this? it means that i cant sand a piece becuase ill have to true it up again when i reverse it?
Any ideas on whats causing it? i dont think its vibration because i thought it could be so placeda cup of tea on the bench while making it and there was no movement whatsoever. could it be the tenon itself? not quite flat?
I just cant work out why its not staying true when turning it around.
thanks for help.
Alie
thanks for help.
Alie
