Kevin mc veigh
Big thumbs up for both … tra 001 and the super jaws xl . Fabulous products .
Assuming that it isn't seized and that you've already done a continuity test on the plug, flex and on-off switch, and checked for loose/detached wires inside, the next most likely candidate is probably the brushes being worn (a cheap, relatively simple DIY repair), or failing that the speed controller having gone phut! If yours is a type 3 or earlier MOF177e (i.e. 2-tone grey body with orange on-off switch and speed dial) then you probably won't be able to get a replacement controller, although it would still be possible to rewire the router as a single speed tool.I’ve still got it and I’ve had it repaired before but this time I haven’t a clue what’s wrong with it, it’s just dead as the proverbial Dodo.
Quite frankly, unless you are doing solid surface work (which soaks up power), no. It's a superb, powerful router, extremely well built, best in class dust extraction, but not 3 times better (based on street price bring 3 times a DW625). A Trend T11, which is designed to be used in a router table and is under half the price of the Fes, would be my choice... but I bought an OF2200, then found that outAs for the Festool…is it really worth the extra cash .
Assuming that it isn't seized and that you've already done a continuity test on the plug, flex and on-off switch, and checked for loose/detached wires inside the next most likely candidate is probably the brushes being worn (a cheap, relatively simple DIY repair), or failing that the speed controller having gone phut! If yours is a type 3 or earlier MOF177e (2-tone grey body with orange on-off switch and speed dial) then you probably won't be able to get a replacement controller, although it would be possible to rewire the router as a single speed tool.
After DW took over the general finish of the routers did diminish, but if you already have a 177e you could always look for a DW625or a Trend T10 or T11 as a "body only" option, i.e. minus collet, nut, side fence, etc. Some dealers offer these from time to time.
