I have a Kity 619 that has been sitting in a damp workshop and now won't start and the depth adjuster is jammed with rust. The start button relay works but just clicks so the problem appears to be either fuses or the motor. The motor spindle turns ok by hand.
I have started to strip it down to access what I think is the fuse box beside the motor (there are no fuses in the switch block) and have removed the table top and most of the internals but I'm struggling to see how to remove the large,black height adjuster wheel so I can lift out the internal cage holding the motor. I just can't see how to remove this wheel, the only thing I can see is the spring pin that holds the cog in place which would be a pig to knock out in a confined space.
Can anyone give me some pointers please?
thanks
Mike
thanks
Mike
