Need advise on CNC production.
JONEK
New member
19 Jan 2025
Iceland
Good day.
I have a design that I need produced but I am clueless to the production side using CNC. I need to sort out how to produce this at high volume. I may begin with about 50 to 100 pieces. however, if the design proves itself for further production, I may need several thousand.
Firstly, I have no idea what CNC process to use - 4-axis / 5-axis? I designed the wood piece in Fusion 360.
Also, I should add that I am wanting to use solid wood - preferable birch - at 6.5mm thick.
As you can from the layout, there is the general shape - but with the additional drill holes that need to be accurate.
Would love some advice!
Jon
First off, wood isn’t going to enable you to machine to those dimensions, I appreciate you haven’t given any tolerances, but assuming you really need position and hole diameter to be specified down to 10 microns I’m assuming a suitably tight tolerance are also required.
I'm not quite sure what you're asking for exactly - do you have a CNC, or are you intending to buy one?
If you haven't already got a CNC I would suggest outsourcing the manufacture - off the top of my head I would have thought a fiver each, which is a lot less of an investment than the £2000 minimum for a small but accurate CNC.
Why solid Birch? I don't think it's as readily available as other woods like Ash (strong and stable) or maple (hard and light).
I don't know what tolerances you're working to, but 89.94 could be 90.27 the next day!
Is the hole in the top face supposed to be central?
It is dimensioned 11.09mm in one view and the overall width is given as 22.33mm.
