Walter Hall
Hi Merv
The motor plate will show the voltage rating. If it shows something like 220-240/380-415 then it can be wired for an inverter. If it only shows the higher voltage range then it probably can't and you will need to buy an inverter as wizard says.
There is more info on wiring motors to inverters here:
http://www.powercaps.co.uk/wp-content/u ... -guide.pdf
