For those of you that don't follow my Blog, with another couple of coats of Danish Oil, my 'bench frame will be ready for assembly!
I already did a couple of dry-runs yesterday...
...It's always pleasing when your your work turns out to look a lot like your SketchUp drawing!! 8) :wink:
There may be some delay before I'm able to start working on the top so, I'd like to turn all attention to the drawers below.
My plan is to only fit drawers to one-half (vertically) of the lower space between the two rails. Total given height is 370mm, minus two lots of "18mm" for the ply top and bottom of a removable carcase (approximately
334mm, then.
I'd like to use these drawers for the storage of my hand tools (currently, they're all jumbled up in the top drawer of a three-drawer filing cabinet...
). As Seanybaby suggested in another thread, I'm now thinking of a narrow drawer for chisels and the like at the top (100mm fronts???), with a couple of others for wider objects.
Removing 100mm for the top drawer would leave 234mm below... Half of that would make it 117 for each of the lower drawers...
Alternatively, I could go 75mm for the top drawer (maybe less?), leaving 259mm, which would give me two lower drawers at 129.5mm each...
What do people thinking about these sizings? Graduating the sizes would work better, I'm sure. I'd like to keep the bottom one as large as possible, just incase... How shallow do you think I can go with the top drawer?
Your thoughts would be appreciated, as always.
