My scroll saw got left in the rain!!! Is this really bad??
Ives
1 Feb 2012
Eastbourne
I don't usually leave it out on the balcony, and rain doesn't even usually get on the balcony, but I just found my scroll saw on the balcony and all wet! What do I do?
(I need a workshop!!!!!!!!!!!!!!!!!!!!!!!)
If it was me I'd dry as much water off as possible, maybe using SWMBO's hairdryer on a cold setting and then I'd squirt lashings of WD40 into all the nooks and crannies.
Airing cupboard is a good idea, that will help to evaporate all the water inside the machine
Steve Maskery":ijqsmbez said:
Don't switch it on!
Put in the airing cupboard for a fortnight and then see.
S
I can just imagine the reception that suggestion would get in my household!
Jim
Water has no effect on such electrical items at all Ives, if you do not run them wet! A hot air dryer etc should solve the problem as suggested.
Roy.
Take it apart down as small as you can and dry everything out, leave metal work somewhere warm and use loads of WD40
Aidan
WD40 really does chase water off steel (it's about the only thing it does well!). It will inhibit the formation of rust, and later, when everything is dry, you can clean it off and replace with proper wax.
The one thing I would check CAREFULLY is the non-business end of the motor. Water on the carbon brushes of the commutator can cause some damage. As long as you hairdryer it fairly soon you should be OK. If it's an induction motor, there are no brushes to worry about.
E.
