The workbench is coming along slowly but surely. Having decided on what height I wanted to make the front apron I was then able to make the mounting block for the vice. Three 18mm pieces of MRMDF glued together gave the correct height for the mounting block.
The next job was to cut out an aperture in the apron for the vice's rear jaw. Rather than offering the vice up to the underside of the bench, it was easier to place the bench upside down on my living room floor, place the vice in the correct position and mark the thickness and height for the aperture. I set to work with the router and was so engrossed in what I was doing that I never realized the routers' dust extraction port had become blocked. By the time I had finished I was completely covered from head to toe in shavings and sawdust :roll: . Never mind, the messy bit was done now, or so I thought. I offered up the vice to the apron to check the fit and suddenly realized that I had messed up. What I hadn't accounted for was the fact that the bench and apron was upside down when I measured up. Therefore, I had routed the aperture in the wrong end of the apron
![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
:roll: . I couldn't face getting covered with shavings for a second time so I called it a day.
The following day I cut another aperture, but in the proper place this time
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
and glued some wood into the messed up first attempt. The mounting holes were also cut into the bench.
I had a bit of a shock when I saw the price of stainless steel M12 nuts, bolts and washers :shock: So I settled for a meter length of zinc plated M12 threaded rod and the far less expensive zinc plated nuts and washers.
The edging on all sides of the bench was temporarily screwed in place and with the bench top upside down I did a trial fitting of the vice. It fitted nicely and the rear jaw is a nice, snug fit between the front apron and the bench top and mounting block. Looks like I don't even need to bolt/screw the vice's rear metal jaw to the front apron.
The next job was to enlarge the vice's holes on the front metal jaw so that I could use M8 bolts to attach a wooden cheek. I dug out an M8 tap which I had lying around for years and which I didn't know how to use. A quick Google search on how to cut a thread seemed quite straightforward so I gave it a go. It couldn't have been simpler. The existing hole was a close enough size that I didn't even need to re-drill it and the existing threaded hole ensured the tap stayed perfectly upright and went in nice and straight 8)
The next task is to get going on the underframe
