YorkshireMartin
God I'm opening myself up here but we're all in for that from time to time as we learn. As some of you may know, I consider myself a beginner, slowly working his way forwards.
I took my first commission a few months ago to build a trade show display stand for a client. Design supplied by client and then refined further. This is my first ever job that I could consider cabinet making. Forgive me if thats not the right term.. Part of the brief was that the piece had to be easily portable, durable and reusable.
Material is 18mm birch throughout. I've thanked him in private but I'd like to publicly say thanks to SteveF for the suggestion of buttonfix. These enabled the complete portability of the finished piece, despite it standing 2.4m when fully erect.. impressive eh? (hammer). Buttonfix are very good indeed and I would recommend them to anyone with a similar brief. Not cheap, but good quality and strong. Finish was Osmo 3044 raw. This results in a flawless natural finish for the light coloured birch, despite the fact that it's white when in the can. Pigment offsets the "damp wood" look you'd get with a "natural/clear" finishing waxoil.
I've attached a couple of pictures showing the final assembly fixings and the unit itself part way through being dressed.
Material is 18mm birch ply of course, BB/BB grade. Some warp as the client kept it on its side, so joinery was less accurate than it could have been. Theres a little bit of cumulative error due to this, but nothing that most people would notice. The client is very pleased indeed and as can be seen from the photo, has set about dressing it ready for it's job at the conference.
Overall, it's been quite a challenge for me. I knew from the start that something this tall would require excellent accuracy and I tried my best. Things I've learned on this project:
Buy quality materials and insist to clients that you will only use materials you specify yourself as the maker;
Don't assume ply sheets are flat or square to begin with;
Don't skimp on marking out, particularly board orientation and male/female joint connections;
(re)calibrate your tools at intervals throughout a project;
Triple check measurements;
Ease all edges to avoid splinters and tear out after the fact;
Don't get too hung up on finishing the non-display side of the piece, beyond making it presentable;
Have confidence in yourself when you feel the bar is set higher than you are comfortable with;
Divide a large piece into several smaller parts, to avoid getting overwhelmed by components in the workshop;
Utilise scrap for test cuts, particularly for unusual angles or where friction fit is required. By being careful, I was able to friction fit a couple of the internal backs, a la chippendale. They literally ended up sliding in thanks to gravity. Not something i ever saw myself being able to do;
You can never, ever, have enough clamps but if you have to make boxes, make sure band clamps are in your armoury!
I am quite happy with the overall result and it's been a great confidence builder, because hey, it didn't fall over and the client liked it.
The only downer is that I am sure someone with more experience could have knocked this up in a couple of days. :lol:
Onwards and upwards?
