gidon
Finally got to my workshed - 10 weeks after the baby was born! Had a load of 2" thick oak I needed to dimension for a front door. Not the easiest job to get into but can't move in there without doing it.
Before Christmas I changed my workshop around and swapped the p/t from one side to the other. For the first time with this arrangement I converted to a thicknesser, set-up my roller stands, opened the door to allow passage of the 6' lengths of timber and away I went ...
I proceeded to cautiously pass the heavy length of timbers through the thicknesser. Couldn't understand it - the rollers weren't grabbing hold? Checked the height adjustment - check, checked the rollers were on feed, check. Tried again! (Can you see where this is going .) Fortunately decided to turn off and have a closer look.
Well guess what - I was passing the timber through the wrong end!!! Same direction of travel as I was used to, but of course the machine was the other way around! Luckily no accidents - I just felt very very silly. I'm sure the lack of sleep is destroying my brain cells. I'll have to stick some stickers on the machine so if I ever have another break from the workshed I won't do the same thing again!
Gidon
Gidon
