petermillard
I do apologise, it's the 1/2" track from Rutlands that works with the Festool clamps - memory definitely not what it was, should have checked before posting!
petermillard":1qfjlzju said:I do apologise, it's the 1/2" track from Rutlands that works with the Festool clamps - memory definitely not what it was, should have checked before posting!
Wizard9999":1qfjlzju said:Pete
If you inset the track in the top of the table won't that restrict you from being able to cut on it. I see you mention resting sheets on top of some dogs, but would this be stable?
Terry.
Couldn't say, I'm sorry - I've only ever really used mine with rail clamps, flag stops etc...PeteG":3hm6vb7y said:Would the 1/2" track give more attachment options?
In my MFT I routed a channel to take a scrap strip of MDF as an inlay (just held in place with double-sided) where the blade cuts; makes it easier to replace after repeated use, and also means you can make bevel cuts without chewing up your worktop.I had planned to make one cut/channel in the table top with the circular saw, and use this as a guide for cutting any sheets in the same place. Unlike the MFT top, I've no plans on replacing mine
petermillard":2qr5gt0k said:In my MFT I routed a channel to take a scrap strip of MDF as an inlay (just held in place with double-sided) where the blade cuts; makes it easier to replace after repeated use, and also means you can make bevel cuts without chewing up your worktop.
Wizard9999":213oo1xx said:petermillard":213oo1xx said:In my MFT I routed a channel to take a scrap strip of MDF as an inlay (just held in place with double-sided) where the blade cuts; makes it easier to replace after repeated use, and also means you can make bevel cuts without chewing up your worktop.
=D> that's a very neat idea that I think I will have to shamelessly copy!
Terry.
bugbear":3gnn5v0u said:They're higher profile (vertically speaking IYSHIM) than I was expecting.
BugBear
