Trevanion
Greatest Of All Time
Yes, they were designated "TM1" or "TM3" depending on whether they had single-phase or three-phase motors. There were a couple of other very obscure models like the "STM" which could be used as a spindle moulder with the sliding carriage removed and a regular table put in its place, and there was the "DTM" which was a double-ended machine for doing a tenon on both ends of the workpiece at the same time, but they were so fiddly that it took more time than just flipping the workpiece around and re-running it, I've never seen a complete machine but I have seen them separated.
I haven't got a clue what the bearing numbers are but I would assume they're a standard metric size, unless someone chimes in and can confirm the numbers I would suspect you'll have to tear down the machine to find out which would be the best course of action anyway so you can have a solid confirmation on the bearing size. My Multico Thicknesser, for example, is a pretty early model that uses imperial NLJ-1 self-aligning bearings on the cutter head and to source new ones are about £50 a pop, the later models used a more standard metric bearing which were far cheaper. I'd probably wager that the TM tenoners all have the same bearings though, but you can never be certain.
I almost always use SimplyBearings for my bearing needs because they're usually cheapest for SKF bearings, and they're still open.
