Moving a 320Kg bandsaw?
Deadeye
21 Aug 2017
Buckinghamshire
I've been looking to upgrade my bandsaw...and have found a Startrite I like the look of, and will fit under the ceiling (!) of my garage.
But it's 320Kg!
Now, I can hire a van ok, but getting it in/out and across the floor when I arrive?
Any tips? It's over three times my current saw weight and that's difficult enough!
Sadly the ceiling joists are the zig-zig sort, and over quite a long span, so not really ok to hoist on.
Advice much appreciated, or should I stick with what I have?!
Lie it down before it falls down. Maybe on the back (spine). Get a wheeled dolly under each end like a piano mover would use. Those can take a huge load and easy enough to make yourself with doubled up 18mm ply and big garage type castors from machine mart or ebay.
You'll need blocks, clamps and ratchet straps to secure the dollys to the machine.
Or.
Keep it upright, screw it to a board and feed rollers in one after the other as you push it along. Even a few wooden broomsticks should be sufficient.
If you lie it down, then getting it back up is a job for levers and props. Ratchet straps to stop it going sideways. Or borrow an engine hoist. It's amazing what two blokes, a lever and some blocks can do. A trestle helps too.
Remember that when righting it, you're only lifting half it's weight but you must pay 100% attention, go slow and talk to each other constantly before doing anything. Surprises are the tricky bit - someone pulls or pushes when the other isn't expecting it. You watch where it could fall and never get underneath it.
You'll almost certainly need to hire a luton box van with a 1/2 ton tail lift BTW and you will need help.
I find it satisfying when you've moved something heavy (even a couple of tons, but with more gear than you will have). A 1.4m prybar is one of my favorite tools. One bloke can get 3 tons up on blocks with that but someone else needs to slide blocks in as you inch it upwards side by side.
I'd be interested to know where all the weight is coming form - it's not *that* much bigger than my current but 320Kg vs 100Kg.
If I took the wheels out and table off...?
And there could be 20kg in the motor.
Doors often lift off or unscrew as well.
Wheels and table must account for a great deal of it but a higher performance bandsaw will have thicker steel and more of it in the frame to allow it to tension wider blades properly.
I guess that must be it - a sturdy frame. The motor is only 900W
320kg does sound a heck of a lot! Have never weighed my Startrite 352, but can move that around fairly easily. Out of interest, how did you get that weight - it's a bit beyond your usual bathroom scales!
It's quoted on p.5 of the manual here: https://sharkbandsawblades.co.uk/downloads/woodworking_vertical_band_saws_handbooks/S1 and S5 Handbook 4E WM.pdf
I must say it does sound extraordinarily high.
I wonder if it was 318lbs and someone has taken that as Kg and then re-converted to 700lbs
The 14-T is very similar but with a slower motor it is quoted as 570lb, the 700lbs is also a gross weight which if these were shipped in a wooden crate (back in the day) then it could have 100lbs of packaging.
The construction of the machine has a much more substantial frame and is advertised as deflection proof so quite likely it's just extra steel adding the weight. Which if that's the case removing table, motor, wheels may be of limited benefit.
Big boggers! https://www.ebay.co.uk/itm/375490588801
Removing table and blade would make manhandling a lot easier.
Looks like a pallet trolly and scaffold board job, plus two blokes and van with high enough roof (or open pick-up) and a tailgate lift.
Easier if it's on a pallet to start with but not essential. Pallet trolley needs three scaffold boards as it's a three wheeler. Or 6 so you can run off 3 on to the next 3.
If it's a much lighter 352 then one chap, a sack trolley, an ordinary estate car.
It is actually best to remove the table from any heavy bandsaw for moving as the trunnions can easily get broken. No need to know why I know this.
John
