I have the wixey angle setting device which is very accurate and the device for measuring the distance from the fence to the blade on my contractors saw and that too is accurate. Perhaps you have just been unlucky?
Hi Tony,
Did you purchase the unit via us (Allendale Electronics Ltd), as I have no record of any customers contacting us regarding accuracy issues on this unit,
Please drop me an e-mail at [email protected] and I will get an engineer to reply to you.
Alan Ward
Tony did you get yours from Allendale electronics because as he has taken the time to post on here offering help if you did, then it would be nice to let us know whether it came from them or not and if so has the engineer contacted you?
In fact I am surprised that no one has thanked Alan for posting the message and trying to help, or even acknowledge his post
Thanks Alan
Mike
Alan Ward":hypwd3l4 said:Hi Tony,
Alan Ward
ike":3becmkie said:Curious, so I took the Mitutoyo apart. Looks like an inductive sensor that utilises the vernier principle to increase resolution. If the Wixey is same then that rules out simple dirt/dust oil contamination. Can you positively rule out the adjustment mechanism of the machine as the culprit?
Ike
1. A faulty readout can have 4 possible symptoms. A. The readout is stuck on 0.0. B. The readout scrolls random numbers uncontrollably. C. The readout is blank. D. The readout produces a consistent error that is always a multiple of 5.08mm ( 5.08, 10.16….etc) A very small error like .7mm has never been found to be caused by a faulty readout.
2. If the bottom part of the frame is not level or slightly above the planers table you will get a calibration error. This error will be consistent regardless of the thickness of board you are planning.
3. If the readout is binding on the scale, the scale will lift with the readout as the cutter head is raised up and down. This is the most common cause of small errors. We suggest in the instructions that you should be able to lift the scale and it should freely drop back down to rest on the frame under the force of the spring. If this is not happening then the brackets will need re adjusted and possibly bent a little to keep the readout from binding.
Other than these 3 things, loose screws on the brackets are the only other thing to check.
