Mortising attachment for drill press
b8el018
New member
30 Oct 2014
Steyning
Hi my dad bought a new drill press and he said he didn't think you could get mortising attachments, I found out that some drill presses can have them. I wanted to know if my dad's drill press will work with any mortising attachments so I can buy him one for his birthday.
Here are the Specs:
Base Size 330 x 203mm
Chuck Captype 13mm Keyless
Chuck Travel 60mm
Collar Size 55mm
Diameter Of Column 59.5mm
Drilling Capacity 13mm Steel
Height 710mm
Max Chuck To Base 340mm
Max Chuck To Table 230mm
Model AH1302DP
Morse Taper No
Nett Weight 28kg
Overall L X W X H 500 x 280 x 710mm
Power 250W (230V 1ph)
Rating Hobby
Speed Range (5) 460-2,480rpm
Spindle Taper B16
Table Size 190 x 190mm
Table Tilt -45° to +45°
Throat 125mm
T Slot Size No
And here is the exact drill (I don't have permissions to link) Axeminster AH1302DP
If you know any attachments that work it would be even better!
Thank you from Louis :mrgreen:
They don't work well, and results would probably be disappointing.
See the other thread for more detail [Mods: suggest merging this one with it, if possible].
In terms of birthday/Christmas presents that are drill-related, how about:
clamps,
a machine vice ("drill press vice"),
a set of Forstner bits (the Axminster ones have a nice wooden case!),
a magnetic-base work-light (really good for a drill press!),
sanding drums (the Carroll sanding drums are way better, but I can't find a URL - they may be no longer with us :-( )
or even:
http://www.axminster.co.uk/axminster-pillar-drill-table
