Morticer chisels & bits
Rob, I suspect Pete relieved the inside corners as can be seen at the bottom, here.
I seem to remeber Scrit saying that the outside faces should never be lapped (apart from to remove a wire edge from sharpening) as it can cause the chisel to stick in the mortice.
You're right about the lapping. But having a slight taper on the chisel would help to prevent it from jamming in a deep cut (aren't Japanese chisels designed like this anyway?).
As for working on the inside of a chisel, apparently it's worth filing out the inside corners with a small file.
Philly I appreciate the offer have a look at this hastily badly done pic and see if there are any questions. Photo is of a different size one 5/8"
Alan
