Ahh, I get it. 2 1/2 inches ahead of the abutment. I never considered where that line would be and instead just measured the desired front angle of the escapement and the desired wear angle and wear height.
richarnold":2t3sts5f said:......."Next, with a very strong gouge, and mallet, sink down to a level of the bed line and front line, using a guide from time to time to see that you do not go too deep."
I think this is one of the most useful pieces of Armour's work, as I find the gouge and mallet approach by far the quickest way of removing the majority of the waste.
[/url]![]()
Hi Giuliano. Its about 16mm across, and has a medium curve. Its quite thick and strong as wellac445ab":37n5s45u said:richarnold":37n5s45u said:......."Next, with a very strong gouge, and mallet, sink down to a level of the bed line and front line, using a guide from time to time to see that you do not go too deep."
[/url]![]()
I never tried to use a gouge for removing the waste, What is the dimension and curvature of yours?
Giuliano![]()
richarnold":mjog4s5j said:Hi Giuliano. Its about 16mm across, and has a medium curve. Its quite thick and strong as wellac445ab":mjog4s5j said:richarnold":mjog4s5j said:......."Next, with a very strong gouge, and mallet, sink down to a level of the bed line and front line, using a guide from time to time to see that you do not go too deep."
[/url]![]()
Giuliano![]()
richarnold":20bbn6f8 said:......then with a thin chisel knock away the wood to the bottom of the front. This is called the ware. Now we have an opening right through. ......
Armour makes this sound very straightforward, but I always find this to be the most taxing part of the build.
Hi Giuliano.ac445ab":39berpb6 said:The plane looks great and, as usual in your planes, it shows an original touch with that strike button.
How is it inserted in the plane body?
Ciao
Giuliano![]()
Ha, well spotted.!D_W":1vm2g9v1 said:Is that blood on the side of the plane body?
Plane looks good, by the way. I've never seen a start that looks like that.
richarnold":2v3jfj9r said:Ha, well spotted.!D_W":2v3jfj9r said:Is that blood on the side of the plane body?
