Bigbud78
So if I was to get the Sorby do I need the Proset & Long Grind Jig ? Yandles have the lot for £340 or I could just go for the delux set from poolewood for £320.
I ordered the complete set from Yandles. The Proset and long grind jig look nice, and I think are probably worth the extra cash.Bigbud78":rdpl0mb9 said:So if I was to get the Sorby do I need the Proset & Long Grind Jig ? Yandles have the lot for £340 or I could just go for the delux set from poolewood for £320.
sploo":3jncfd96 said:I ordered the complete set from Yandles. The Proset and long grind jig look nice, and I think are probably worth the extra cash.Bigbud78":3jncfd96 said:So if I was to get the Sorby do I need the Proset & Long Grind Jig ? Yandles have the lot for £340 or I could just go for the delux set from poolewood for £320.
Whether you need them is up to whether you're going to do some long grinds of gouges. As a totally new turner I've no idea myself, but for the tiny difference in cost I thought it was worth getting them.
They also ship a Trizact belt with that kit. Unfortunately, the extra bits Yandles add are obviously not in the Sorby Deluxe box, and were just placed inside the shipping box. No problem for the Proset and long grind jig, but the Trizact belt didn't take kindly to being slam-dunked by the ProEdge box in transit and probably isn't usable as a result.
Yep; sent an email on Saturday, but no answer.Bigbud78":1bigxdmm said:Have you contacted them about the belt, surely they will sort it for you ?
I've only used it once (on a roughing gouge and a parting tool) but the results were fine. Given I've no prior experience with wood turning chisels or the ProEdge I guess that's good.Bigbud78":2luq3uv9 said:Ordered the Sorby and it has arrived, looking forward to sharp tools
selectortone":38du1bx3 said:Here's my modest sharpening station. The Record Power grinder was, if memory serves, a penny under £60.00 on a Yandles sale day and the two jigs together were about £50.00 off ebay (they are on there regularly). I improved the tilting platform with a Bristol locking handle, again off ebay. I splashed out on a CBN wheel from Axminster (£105.00) after using one at my teacher's place but the two white wheels I had on there did a perfectly adequate job.
I do my bowl and spindle gouges on the CBN wheel and my scrapers on the white one. Skews I tend to sharpen by hand with a diamond hone; that way I don't disturb the scraper angle on the platform. I was a guitar builder/repairer before I retired so I'm used to sharpening flat chisels by hand.
So, I'm into that lot for a little over two hundred quid, half of which was for the not totally essential but absolutely fabulous CBN wheel. The important thing as far as I'm concerned is that the rig is right at my elbow when I'm turning and putting a quick edge on a tool is very easy and quick. There's nothing worse than fannying about with ancillary gear when all you want to do is turn.
BearTricks":34yqr917 said:..
How's the vibration on the record power grinder? I have a cheap screwfix and it's unbearable.
BearTricks":3qjo7eg2 said:How's the vibration on the record power grinder? I have a cheap screwfix and it's unbearable.
Bigbud78":25lbjfr4 said:Sorby user's can I question RE: spindle and bowl gouge angles ? Whats everyone using ?
Ive put a standard onto my spindle gouges all at 35deg's but was going to buy a 3/8th to put a finger nail grind on for finial work but found that using the proset the over hang is massive for 35 degs! Anyone noticed this ?
Also going for a fingernail grind on my bowl gouges whats recommended angle ? 50 ?
That's a really useful video. One of the things I'm struggling (with books, and even many videos) is to see the subtlies of exactly how a tool is controlled, and what part of the cutting edge is being used. I haven't seen any of Drozda's videos before, but whilst that was intended to demonstrate her particular grind, it was very helpful in understanding the required movement for different cuts.woodpig":1yhf3i4j said:
At the moment I'm more at the stage of what tool (and what movements) you'd use in order to create a particular shape. Getting good at making those movements smoothly will come laterCHJ":lo7lhibc said:One of the most significant things you can do to get good gouge control is to keep the tool handle tucked into your body and control its path by pivoting you body not just your arms. Of course there are many situations when this is not possible but if you once experience the smooth flow of a cut by swinging your body you will translate a similar feel and support endeavour to other cuts.
