If you’ve never used a Silky then I recommend you try one - its amazing what you can cut with surprisingly little effort. I have the small Pocket Boy Curve and it’ll go through branches 4 inches diameter no problem. Best bit it it folds up and goes into a pocket. I expect the bigger saws are just as capable.
The only negative that I found is knowing which one to buy (first) because there is a huge range.
