colinc
Hi,
a while ago I bought a 2nd hand Kity 419 and it has become a very useful part of my workshop. It is mounted in a wheeled workstation with extra table area to the right and behind and its own sliding table on the left. The biggest problem is the dust extraction so I have pulled it apart to remove the side plate of the the casing around the blade and have mounted an Axminster big mouth dust hood in the table below.
However, before reassembling everything and setting the saw up again, I thought that I would have a look at improving the blade angle adjustment to see if it could be improved as I remembered reading here that one member had modified his to use a hand wheel type adjuster instead of the existing toothed knob and quadrant rack system. Unfortunately I don't think he ever posted any pictures. I found the best clue as to what to do was in the parts diagram for the Axminster TS200/250 and my modification takes some inspiration from that.
I am quite pleased with my prototype and am posting a few pictures in case anyone else is interested.
regards
Colin
regards
Colin
