Hi Andy
I wasn't quite sure there mate...but thank you for your compliment...
I will bring it to the YOKB II so you can play with it if you are coming...?
Well...I am really happy today...firstly because this hardening business with the kiln is now becoming second nature to me and the temperature control and tempering are getting done with far more accuracy and evidenced by the resultant hardness and keeness of the edge...here is the iron...
One thing with the 01 steel that I get is that it is textured and dipping it in oil causes blackening which is a nightmare to get out of the grain. However...in order to create an apparently aged look...this is a bonus as a quick whip on the wire wheel and then the buffer makes it look antique...which is just what I wanted...and it sits beautifully in the mouth...
So...how does it shave? Well there is only one word for it...superbly!
Here is a piece of rough-sawn cherry that I chose to test it with a rebate...
Before is on the left :roll: and after on the right :mrgreen:
It makes that whizzing noise....and this was deep set so if I were to fiddle with it I could get a MUCH finer cut but I wanted to play so...
....the finish is like silk....
...this is FUN!
Well....I'm really happy with this little baby...the iron taps in really well...I might put a bottom sneck on it but not sure yet...it's fairly easy to set well...and once set for a job needs no adjustment at all.
So...now off to fiddle with the toe of the wedge to prevent shaving bunching with my favourite plough pattern...polish off the bevels and generally tidy it up to remove scratches but I'll leave you all with this...
More later!
Jim
