This proved to be a very helpful thread for me; so thank you to:
@johnnyb for raising the questions that were germane to my problem
@TRITON for linking to a very good deal on some chisels
@ChaiLatte for linking to some very good deals on the Katsu router and offset base etc (unbelievably cheap)
Anyway, I have now successfully used this strange offset router setup for routing out some unconventional hinge recesses in some window frames in situ. I will add a couple of photos and a bit of explanation as it has been very useful and I didn’t know such a thing existed before seeing this thread.
The job is to recess some (30) custom-made cranked projection hinges on the front face of some window frames. It was a long story as to how we ended up with this design problem, but in short I designed the hinges for some stormproof arched windows to allow the window to open without the curved head fouling on the arched exterior wall reveal (I never liked the window design, but we were where we were and this was the only practicable solution.) The hinges work well in fact, but they were poorly fitted by the on-site chippy and now after many years I am refitting them (hopefully better!). These required rebates abut the exterior reveals and are high up on the building - chiselling out precisely is never easy with softwood and I didn’t fancy doing that.
Hopefully these pictures show much of how I did the routing:
The offset base gets to within about 8mm of the edge I think - that final bit does need cutting/ chopping out with multi cutter and chisel, but that is very easy from the routed reference.
I used a flush bearing guided bit from Wealden (8mm shank) - by sticking on a 6mm mdf base this was a good starting point for the required depth - I fine tuned the depth by adding some 8mm washer shims (I bought a selection of 1.0mm/0.5mm/0.1mm on eBay). Slipping the required shims onto the shank of the cutter gave very precise adjustment. The only remaining problem was the varying thickness of the nasty old plywood I had made my template from and the Katsu base is not very rigid particularly on the offset part.
I now need to make a replacement base or maybe two in differing thicknesses - does anyone have any suggestion re the best material for this (phenolic or acrylic?)
