Doug B
Shy Tot
OPJ":8zglfrn8 said:You can see how these saws (even the Kapex...? :shock won't cut them spot-on every time.
Think Mr Festool might disagree with you there, Olly :lol:
This one's in 'noir' :roll:wizer":22w7goag said:swanky. I'm jealous!
Agreed, all bits need to prepared accurately to give yourself a fighting chance of bringing them together. Pieces also need to be dead parallel as it's opposing edges of each piece that are placed against the fence to shute the mitre...if they're even a tad out, the joint won't go together. Not too bad in a small pic frame, but in a box (say) with a 100mm long mitre, the discrepancy will show :evil: - Robfrugal":5y7hz50s said:I can not get mitres to fit correctly when doing them on a shooting board with a handplane, they always come out just out enough to leave one open crack when I put it all together. I have managed to ge the disc sander set up to do mitres as the table drops down to 45 degrees and is accurate.
Like anything else woodwork related what you get out is only as good as what you put in. I was pulling my hair out trying to work out why I could not get the mitres to fit on a small box. No matter what I tried the mitre ended up curved rather than straight. Turns out that since thicknessing the wood it had cupped slightly, not enough to be obvious, but enough to throw off the mitres (at which point the pieces were of course too small to put back through the thicknesser :? ).
Now before even trying to mitre anything I make sure that all of the pieces are the same width, they they are not bowed, cupped or twisted at all (no more thinking that it will all come out right in the end if I use enough clamps) and I get the digital calipers out to ensure that it is the same thickness all over and that every piece is exactly the same thickness ( I measure this down to 0.1mm as I am making small jewellery boxes).
What's a shute?woodbloke":1n5g4xb7 said:This one's in 'noir' :roll:wizer":1n5g4xb7 said:swanky. I'm jealous!
The problem with mitres for a box or frame is not just cutting them at 45deg which is easy enough even with a Kapex, but cutting all four bits identical (or two pairs identical) This is where the shute has (I think) to score 'cos you can take just one shaving off (thou or two maybe) a mitre where needed to bring it into line with the other bits of wood - Rob
*looks at thread* Um, nope. As Rob says in one of his posts, even if you cut it with a machine in the first place, using a shooting board is an excellent way to get the most accurate fit. I concur, but there didn't seem much point in repeating it. :wink:PerranOak":11zd3z7h said:So, basically, they can't be done without machines!
Alf":265ccvge said:*looks at thread* Um, nope. As Rob says in one of his posts, even if you cut it with a machine in the first place, using a shooting board is an excellent way to get the most accurate fit. I concur, but there didn't seem much point in repeating it. :wink:
