PerranOak
I've been making drawers with dovetails.
I tried to make a small (100mmx100mmx40mm and 10mm thick stock)drawer insert with mitred corners - wanting a quick result.
I cannot get it right!
I use a shooting board with a 45degree "block". However, the slightest tilt on the plane or movement in the block and wallop! Any error is multiplied 8 times (eight surfaces to be planed). I can't achive such accuracy consistently. Unless they're accurate, the gluing surfaces will not meet properly and the joint will be weak.
How does everyone else do it?
