StevieB
I have been eyeing up a mitre gauge for a while now, with most seeming to fit a standard 19mm x 9mm slot (3/4" x 3/8"). As I have an old Startrite TS I figured I would have no problem, but before pressing the order button thought I had better just check the slot dimensions. width - 19mm - check. Depth - 6.5mm :shock:
Does anyone know whether the bars themselves are 3/8" (9mm) in depth so it wouldn't fit in my saw (ie it would be 3mm proud of the table) or whether the bars are thinner that that and the 6.5mm I have would be fine. It is a second hand saw so no idea if this is the original depth of the slot or whether the table has been surfaced previously and some depth has been lost.
I know I could (probably) replace the bar with something that would fit the slot I have, but would rather not if I can get away with an off-the-shelf product. I was looking at the Incra V27 but if there are alternatives with thinner bars I am open to suggestions.
Cheers,
Steve
Cheers,
Steve
